- Tranquility Base
- FSH Sport
I’m looking at improving the raw water wash down system on my 210. The OEM system works pretty good but is a little light on pressure and flow. To be fair, the OEM system gets the job done.
If both engines are running when you use the OEM system, both engines throttle up when you toggle the wash down system to raise engine rpm / pressure.
What I was thinking of doing was to utilize the same port that is used by the starboard jet pump but is on the port side pump and is blocked off, to augment the OEM set up. Wanted to just copy it but on the port side, use the bulkhead valve and put a check valve in both the port and starboard side feed lines so single engine use would still be possible.
Or, install a traditional 12 volt powered pump by tapping off say the live well supply and then tie it into the OEM System..
Has anyone upgraded their OEM wash down system?
