props2you
- Round Lake, IL.
- 242 Limited S E-Series
[USERGROUP=9]@HELP[/USERGROUP]
This has happened to me the past two weekends. Both scenarios have been identical:
At launch, both engines start & run fine, no issues. idle, stop, start, go etc.
After running (stopping & starting intermittently without issue), will go to the beach, anchored in 3-4 feet of water and sit for 4-5 hours on house power running stereo etc. Upon departure, (voltage is fine for both house and start @ 12.4v) both engines start, starboard engine has no issues, starts and idles at 1200 RPM. Port engine will start and idle at 1000 RMP. Upon engaging both motors to full power (either individually controlled or single lever option) port engine maxes out at 2000 RPM. No issues with starboard.
I will turn the key off, fully power the boat down and let it sit for 10-20 seconds, power everything back up, turn on the key and start both engines and the port engine will go back to normal idle at 1200 RPM and have full power back.
It is throwing a port engine alarm and diagnostic code (which I cant see specifics, just the code [HASH=410]#)[/HASH]
New plugs this season, there is no blockage and coolant is running through both engines, both cleanout plugs are seated and secured, seems to be an electrical gremlin somewhere...
Could this be a misconfigured battery connection?
Any help or place to start would be greatly appreciated, dealer is 3 weeks out...UGH!
