Remove front seat back
spaz944
Cape Coral, Fl
How do you remove the seat back to allow access for the helm. 2012 SX210. Want to access the back of the radio.
Thanks.
Bill D
Prairieville, LA
octavio3311
Brookfield, Ct
Remove seat. Reach up and feel for nuts or wing nuts - my 212x has wing nuts - undo wing nuts. Gently Pull out bottom, then lift cushion up.
octavio3311
Brookfield, Ct
Didn't have time to elaborate. Had to pick up my son.
Anyway - remove starboard seat cushion and then reach in behind the seat back. The lower portion is held on with wing nuts - the upper portion have brackets that insert and rest on other brackets. Once the wing nuts are removed, you will be able to pull the bottom portion out towards the bow. Once the bottom portion is out, then gently wiggle and lift.
spaz944
Cape Coral, Fl
I got it figured out. Thanks for the replies.
