captainhook
- Southern Maryland
- Limited
I can't figure out why this is happening, when it started, or if I caused it by changing things but I noticed it this year. You can't hear it while at the helm but I noticed that the jet wash on the starboard side looked like it was pulsating a bit compared to port. I changed the control cables last year and added a used set of Thrust Vectors and thought that was causing it and some spray from the starboard side, so I bought a nicer used set of Thrust Vectors and had the same exact problem with the spray. Thinking that the Thrust Vectors being spring loaded was the problem, I bought a brand new set of Cobra Jet Ultimates this year and set them to the "always down position" and there is no longer any spray, but the jet wash still seemed to be pulsating. So I took my daughter's GoPro and selfie stick and decided to take a good look and my suspicions were confirmed; the bucket is bouncing in the jet wash.
I took the entire binnacle/throttle assembly apart yesterday and found no obvious issues. There is no additional play up and down or left and right in the starboard bucket compared to port. When I put both throttles forward, both buckets appear to be in the exact same position, same with neutral and same with reverse. What the hell could I try next??
