S.peay
- Bowling green kentucky
- Scarab
- HO Impulse
Hm someone a little too drunk or forgot the plugs?
Bummer. Sounds like he took a wave (or three ) over the bow. I wonder if that boat has a scupper.
I understand that Scarabs do not have scuppers which certainly could become an issue for Bimini crossings.Wow! That's crazy. I agree with @itsdgm and wonder about the scupper.
Its definitely a carbon seal. If the boat has 17 hours, then it could have worn due to two things. 1. Engine/pump alignment or 2. Engine flush for more than 2 minutes.I'm not sure because I hear him say it had 17 hours at one point and he said he took some wake over the bow but it sure looks like carbon seal... if not he did a hell of a submarine
The engine is closed loop, but can take in water through the intake, and exhaust manifold. If you shut off the engine, you can save it from hydrolock. Once you get it back to shore, you can just take the spark plugs out, and crank the engine. The water will shoot out, and it will be ok.I would have gotten the tree people out of the boat or AT LEAST tried bailing the water. Too nice of a boat to just sit there and drink a beer. It was getting worse while towing with all of that weight, they could have moved the people to the other boats.
so if the motor cut out right away they could be ok right? Just have to remove all water from the engine, change all fluids? If it sucked up a bunch of water, not sure what happens.
