ZippyBoater
- Lake Gaston, VA
- SX
Purchased my boat in late September 2018 and when I put it in the water for the first time, I found out that the scupper valve was broken and I was taking on water. This forum really helped me ID what was wrong and how to fix it. While I was waiting on the replacement valve and cooler weather to make the repair, I plugged the hole in the hull where the scupper valve goes thru with a PVC Test Plug and I used it for a few days without the boat taking on water. After a lot of research on this forum, I am beginning to believe that plugging will be the easiest and safest way to go. We don't get a lot of water in the boat as we use it on a very calm lake and we have a covered boat house where it is stored.
My question for the group is, do I really need to replace the valve or can I just find a more permanent plug for the hull?
