@justinhernandz
- Altamonte Springs, FL
- FSH Sport
I think you can connect the JL head unit to the simrad without a black box with a NMEA connector.Nice work on the installs!!
I just pulled the trigger on one of those Simrad GO 12 units as well, but I will not attempt the install myself... I am not ready yet lol! The installer here will take care of the MFD and the trolling motor/batteries. Seeing how they did it will give me confidence to do the other parts afterwards, but those two major ones scare me still (first boat owned!)
One thing I am wondering about is the Ridesteady I bought, I am not sure where to install it yet. I have seen it installed as a replacement to the one of the RPM gauges, but I was wondering if it was the best idea to lose one of those? Another option I was entertaining is replacing the stereo with a black box NMEA2k unit, which I could control from the Simrad... and another one was to see if it fits in the flat lip between the no-wake/cruise/washdown and the bilge/horn switch.
Any suggestion welcome, hope I am not hijacking the thread![]()
Yes, you can, I am sorry I wasn't too clear... I am basically wondering where I'll be able to mount the ridesteady gauge with all of that stuff on the panel, at this point it will be a tight fit with the GO12 in thereI think you can connect the JL head unit to the simrad without a black box with a NMEA connector.
I am not familiar with a ridesteady. I’ll look into that.
I'm leaning toward having a custom switch panel created to shink their footprint, hoping that would buy enough room for ridesteady... and just maybe trimtabs. Even with my Garmin only being the 10" it's getting claustrophobic on that dash. Removing the ball compass is an option too.Yes, you can, I am sorry I wasn't too clear... I am basically wondering where I'll be able to mount the ridesteady gauge with all of that stuff on the panel, at this point it will be a tight fit with the GO12 in there
Update
Installed the transducer, JL audio M3’s to replace factory ones, and installed the MM50. Next up is a Sirius XM WM4
View attachment 141251View attachment 141252
I think @zackmorris means do you lose sonar readings and have difficulty resolving the bottom of the seabed when cruising at faster speeds?I have my transducer on the ride plate as well, I haven't noticed any difference in speed. In my environment I see greater variations on speed with boat weight, wind and current.
How do you pull the dash?I'd highly recommend pulling your dash. It makes life so much easier. It's really easy to do. I was super sketched out about it at first too, but it gives you a much better working space and you're not forced into weird angles or areas fighting around the steering wheel/windshield frame.
It looks like Suke does not have a FSH to that wont apply to us.How do you pull the dash?
That was in relation to someone with a 212 that posted in this thread.How do you pull the dash?
Really nice and clean install @SAA_Woodstock where did you purchase the transducer bracket?Installed my Simrad Go 12 XSE with Active 3-1 Transducer. Thanks to the info here I decided to go for it. The screen was a very close fit due to the limited available room on my 2020 FSH 210 console. It will fit, just be careful with placing you cut out template.
The transducer mount bracket comes included with the Simrad GO12.Really nice and clean install @SAA_Woodstock where did you purchase the transducer bracket?
Update
Works great and better than expected. The Yamaha hull doesn’t give many good options for mounting a transducer. After researching about best practices for mounting the transducer, I was a bit nervous. But it works fantastic and very happy with it,How has all of your equipment been working out for you?
