Joe Covelli
- Connecticut
- SX
2013 SX192
Relocating The No-Wake Mode/Cruise Assist Switch
From The Dash To The Throttle Handle
If you are like me, you find the factory location of the CAS, (cruise assist switch) to be in an inconvenient location. For me the logical spot would be to put it on the throttle handle, like the trim/tilt buttons used by the outboard boats. After noticing that the SX192 throttle handle looked identical to a friend's Yamaha outboard throttle assembly, except for color, the research started. In short I was able to order the exact fit Yamaha parts, and make the change over to the throttle. After testing it out it we found it to be an ideal location, so much so that we removed the CAS from the dash, filling that hole with a 12vdc convenience receptacle. The cost was about $70 , and a half days work, but worth every penny.Relocating The No-Wake Mode/Cruise Assist Switch
The round connectors on the end of the throttle cable will need to be cut off so flat spade connectors can be crimped on, matching the boats wiring harness.
Parts needed for conversion were purchased at (partzilla.com), just search the part numbers shown below.
Routing of cable through the shift assy. I also did the throttle drop modification that someone had put in the "Member tips & ideas" section. That is the yellow nylon crimp sleeve pushed & glued at the lower center of the picture. It solved the problem of the throttle slipping backwards.
The next three pics show how to route the cable before installing the shift handle.
The original switch with the new cable draped to the left of it. Before the ends were cut off the new cable.
The connections made to the wiring harness.
A look at the dash.
This is my first post, and I hope it comes out correctly. Good luck if you try it out.
