You WON'T regret going JET
I had a 21 foot IO Four Winns for 19 years. Loved the boat, but spent PLENTY on maintenance. Between seals and transmission gears and U joints, and bellows, and impellers maintenance was always an issue. Not so much that these things failed all the time, although some did, but you have to maintain and replace these items on a regular basis...and it aint cheap....and you cant do most of it yourself. Following the recommended maintenance for the engine and the lower unit was costing $300-$500 per year, and I did my own oil changes and normal pre/post season maintenance. In 19 years, 3 lower units at more than $3000 per....one was because I hit a stump, the other 2 were just wear and tear failures. (But hitting stumps is another issue).
Bought my 242 Limited SE about a year ago....maintenance.....oil and filter maybe $50 per season....normal things like cable lube, silicon spray to keep down corrosion, grease for the impeller bearings and most all other maintenance you can do yourself, and would be hard pressed to spend $100 per year!
Fit and finish....I have no problems with the overall quality....I am satisfied and impressed.
Control....I have not gone to fins....I think they are probably a big help, but I did research and watched alot of You Tube and learned to use the system...and it really does work well. I can far out maneuver what I was able to do in my Four Winns.
Fuel....I burn slightly more fuel with my jet as I did with my IO...but I am running 360HP as opposed to 260HP.....so not a factor.
Storage....it is incredible how much STUFF you can get in a Yamaha.
Reliability and longevity....Yamaha motors are known for their toughness.....they have been making marine engines for years! Also, remember that Yamaha makes just about everything on that boat (engines/hull/etc.) except the radios so it is a one stop shop for warranty issues.
Safety....no prop to worry about for kids/friends in the water....and with 16" or less draft (my Four Winns was 35" draft), shallow water and hitting stumps is not near the concern....remember the lower unit I mentioned above!
I would not go back to a stern drive....PERIOD! Yes, you can find boats that may be a little more luxurious, and with perfect fit and finish, but you have to look hard! I looked at Sea Rays, and Four Winns, and Cobalts! All awesome, beautiful, quality boats. I went with Yamaha's top of the line...spent way more than I should have....but the stern drives I looked at, similar size and equipment were $20-30K more! And I think the fit and finish of mine is comparable!
Not my intention to bash stern drives....for each his own, and I am sure die hard stern drivers can give you their opinion....but having done both, and for my purpose, the jet, and the Yamaha were the best fit!
Good luck in your search....you wont regret going jet !
