- Naples Florida
- SX
Those clips are a pain in the butt!! I learned some new words when I replaced a piece of cooling hose a few years ago.
The hoses are pretty stiff. might be hard to clamp them with that wing nut.Do you guys think this will work? Or at least temporary?
http://m.autozone.com/autozone-mobile/en/accessories/OEM-Hose-pinchers/_/N-26on?id=191675
I have these also. they are great for an emergency.Installed mine in the glovebox. I've never had to use it in 11 years. I think the $17.99 was worth it though.
same here. keep a pair of them in the boat at all times - just in case I ever need to get towed. Never used in 8 years. But before I had these, I towed my seadoo thinking the odds of getting hydrolock from towing at no wake speed was very slim. My thinking turned out to be wrong and I had to rebuild that Rotax. Been carrying these clamps onboard every since.Installed mine in the glovebox. I've never had to use it in 11 years. I think the $17.99 was worth it though.
Leave them open if you're not in the water, so the pump pickup gets flushed too.I have them closed so I can flush the engines without loosing water out of the pumps. I open them when I'm done
If you were to keep you're boat in saltwater for a week, shutoff values are much better. Hose clamps are fine for an emergency.I have to admit I don't even have hose clamp pliers in my glove box....13 years and counting with twin engine Yamahas and never needed to clamp a hose. If I was going to bimini, I'd buy a pair of pliers....
I've not studied the exact hose routing and heights, but I would think that a shut off valve in the engine compartment would prevent salt water from standing in about 2-3 feet of rubber hose.....or are there metal fittings down there? I know the Y is plastic as some have had problems with them not being manufactured properly and restricting water flow.If you were to keep you're boat in saltwater for a week, shutoff values are much better. Hose clamps are fine for an emergency.
Actually clamps aren't even necessary for emergency situations. They are only needed if you want to push the one engine remaining to greater than no wake speed.Clamps are all that is necessary for emergency issues. That is all I carry but never used them.
On the lake right now and Jackson Brown on the stereo...waves lapping at the boat, Chester sniffing around...cigar smoked, and a nice cab in my glass. Good to be on the water again. Thanks to all for the encouragement and putting up with my journey!
I was referring to flushing the engine...hose clamps will end up damaging the hose if you use them often to flush the engine while it's in the water. IMO, there's no reason for shutoff values if you don't plan on flushing while in the water...emergency hose clamps will work fine.I've not studied the exact hose routing and heights, but I would think that a shut off valve in the engine compartment would prevent salt water from standing in about 2-3 feet of rubber hose.....or are there metal fittings down there? I know the Y is plastic as some have had problems with them not being manufactured properly and restricting water flow.
I carry the same clamps as well. I figure better safe than sorry, but I read something once that made a lot of sense.. On the dead engine(s), put the throttle in full forward position. In theory, this reduces the pressure it takes to get the water all the way to the engine. So I left the hoses as designed by Yamaha and carry the clamps just in case, but will still put the throttle in forward as well.Actually clamps aren't even necessary for emergency situations. They are only needed if you want to push the one engine remaining to greater than no wake speed.
I find that the idea if being towed and me riding in my boat yelling "slow down"! Would be one of those situations I do t want to be in. And even though it is remote that you would be dead in the water, and remote that a boat could tow you fast enough to flood the engines...I'm not taking that chance. So $10 says I will never have that worry single engine or dead in the water.Actually clamps aren't even necessary for emergency situations. They are only needed if you want to push the one engine remaining to greater than no wake speed.
Where are you getting two clamps for $10, or are you just using a basic C clamp?
Everyone has their comfort level. I'm comfortable inland boating with no clamps on board. My glove box is already full....but hummm....it would make for more ballast!![]()
As for flow restriction, it's no more than all the other fittings in line.
