sebagobill
- FSH Sport
I'm looking to add a Minn Kota Ulterra to my 210FSH and had questions regarding the batteries and specifically charging. I don't have shore power and generally keep my boat at the slip for most of the season. This would require me to (I assume) remove the batteries occasionally to charge depending on usage. Anyone else in the same situation? What setup do you have? Should I use Lifepo4 batteries instead? Is under the helm the best install spot? Do you use the stock mount? Any other suggestions? Sorry, that was a lot of questions!!!
Here is the quote from my dealer.
-$2349.99 Ulterra 60lb, 24v
-$58.00 Quick release plate
-$40.00 Circuit breaker
-$88.00 Tr. Motor plug
-$40.00 Sealant, hardware, fasteners, wiring
-$280.00 2 Deep cycle batteries
-$40.00 Core charge for batteries
-$8.00 Fuse
-$22.00 Battery trays
-$2925.99 Parts total
-$750 Labor, 5 @ $150
-$3675.99 Total
With optional 2 bank battery charger:
$249.99 Charger
$75.00 Labor
-$8.00 Fuse
-$3675.99 Total
$249.99 Charger
$75.00 Labor
