SunnyD
- Suwanee, GA
- 242 Limited S E-Series
My 12v outlet is shorting on my 2020 Yamaha SE. I've continuity tested without the fuse and both 12v sockets (dash and port transom locker) and the fuse terminal itself with a negative result. With fuse in, (house battery off obviously) both 12v sockets test positive.
The negative fuse terminal test leaves me most confused since this contradicts the positive tests. It's awkward to get the test nodes in the fuse terminals so while I'm pretty sure I had good contact, I'm not 110% sure.
Any ideas?
Any ideas?
