GiddYupJoe
- Beavercreek, Ohio
- Boatless
- NA
- X
- NA
Yes. But the cross beam is welded to a solid tube. I don't believe there would be any way for water to travel from the tower tube into the cross beam.Do I see a disconnect for power in the pic. Pods running down wires through grommet
Nothing! That's crazy. I actually was driving home last night thinking about it and how I can't be the only one!
I guess my theory of the storage unit owner setting a 2x8 across the tower braces and then stacking crap on it is out the window.
Freezing water is now out also since yours happened in the middle of the summer.
Gotcha. I just don't understand how water could get in there? all the welds on mine were solid when looking at them.Could still be freezing water. I just noticed mine while getting the boat ready for summer. It was a busy couple of months at work.
Ended in Feb of this year. Didn't find out about this till April when I took the boat out of storage.Are you under the YES still?
I wonder if its worth drilling out a couple small holes in both sides prior to this winters storage?The only thing I can think of is there must be some sort of notch in the tower tubes that opens to that area.
