IN2H2O
- Limited
I have a MR-1 (new to me 2008 232) and I've been trying to chase down why my pisser's are not pissing water overboard on one of the motors. I ended up clamping the Y fitting as if I was being towed and ran the motor on the hose for a few minutes to see if the water would build pressure and start going overboard. It never did so I shut it off and have been chasing lines all day.
Just moments ago I Ient to check compression and getting 200 psi in each cylinder and then cylinder 3 pumps 250psi. Pull the gauge out and it has beads of water on it. I put the other 3 plugs in and idled the motor to try and push as much water out as possible. After about 20 seconds no more water seemed to be coming back out. I checked compression and it's now 200psi. I unclamped the vice grip at the y fitting. I put the #3 plug back in and now I'm idealing on the hose trying to drive moisture out. Not sure what else I should do? [USERGROUP=9]@HELP[/USERGROUP]
