- Northern Vermont Lake Champlain
- Other
- Other
- Other
I was cleaning out the boat and WINTERizing today...and was cleaning out the ski locker and saw a reflection of light coming from the drain. There was standing water nearly level with the top of the drain. Tried to un plug using big grass trimmer string, fed 6' into it, water stayed. All drains and plugs are removed and appear dry in the engine bay. Brass plug removed. Tomorrow I will remove the fuel hatch to see whats up but I did not want to leave the water in there with freezing weather almost here, so I got the shop vac out and taped an old plastic gas nozzle to it that fit into the drain hole, and Holy Cow I pulled 4 gallons of water out of there I would not want to have frozen. OK where does that drain go? Under/around the fuel tank? There is an area of space below the engine and those plastic plugs drained by the brass plug, does it drain there. I know how it got in, just wondering why it stopped where it did.
