Will this work?
John Mcpartland
Vancouver Wa
So I have 6 jlmx650 speakers, 2 rockford fosgate tower speakers, jl m10ib, and a wetsoumds stealth bar 10 with a audison lrx 6.9k amp. I was thinking of hooking up the 4 cockpit jl speakers to channel 1 and 2 at 2ohm and the bow jl's and the rf towers to 3 and 4 at 2ohm with the sub bridged on 5and 6. With that said can i use the high power outputs on from the factory hu to run the wetsounds ultra 10 sound bar and the rca to the amp?
adrianp89
Tampa Bay, FL
252SE
Simply put... yes you can.
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
You can, but will WAY underutilized the sound bar and be running the amp at max capacity. I wouldn't do it, just add another amp.
John Mcpartland
Vancouver Wa
I am looking at the stealh 10 surge that has an internal amp, can you run that with an external amp? The other i am looking at is the 10 core that are just the speaker bar and add an amp for that
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Either one of these 2 options would be ok.
Jaylex
@John Mcpartland that amp looks serious, reminds me of those 2400w soundstream amps....do you already have this amp or looking to buy.
Asking since you might be able to get 2 amps for a tad more and power your nice equipment more efficiently, although I too tried to simplify my setup with a single amp.
I'll be installing my 3rd amp in a few weeks so I might not be the best person to ask,lol
If the sound bar is powered it should sound great off the 1 amp.
John Mcpartland
Vancouver Wa
@Jaylex . I do already have the amp, it's sitting in my garage waiting for tje rain to stop.
I started with the amp and 6 jlmx650's, then someone was selling 2 tower speakers on here and I ended up picking those up making 8 speakers. Then of course a had to get a sub adding one more element. Now I just picked up a new wake tower off of a 2018 212x woth the mounts for the stealth 10 speaker bar, if you have them you have to use them, right? I was just wondering if I got the wetsounds stealth 10 surge that has the build in amp if that would work useing the speaker out of the stock head unit and run the 8 6.5's and the sub off the audison amp for now.
Jaylex
@John Mcpartland that sounds like a solid plan, if the sound bar has it's own amp then you should be good to go with the other speakers on the single amp. Plus you can always add a second amp down the road for the sub or towers only if you decided.
Keep us posted....I'll be working on my phase 2 audio install in the coming weeks as well.
Excited to see all the new updates from everyone.
Jaylex
Post pics when your done
John Mcpartland
Vancouver Wa
Keep in mind you will have to run power wires through the tower for the sound bar....might be easier to just run speaker wires (which may already be in the tower you bought)
@Julian yes the speaker wires are there, but i could use those as a pull string if i do go the powered route.
