ralphsmithiii
- Tampa, FL
I've been looking into the proper way to run additional power and ground to behind the helm to power some additional accessories. Currently I have 4 gauge power and ground running from the batteries (JL Marine Fuse by battery) then directly into a JL M8/800 amp. I'd like to be able to correctly run my chartplotter and now a WS-420SQ both being powered behind the helm. I saw some have added an additional fuse box behind the helm (@Benny Sibbitt ) I believe run a new set of 8 or 6 gauge wires from the batteries back to it then tied off from there. I'm wondering if I can use the 4 gauge power and ground I have now (maybe should of run 2 or 0 AWG but I wont want to re-run unless I have to) and break that off to a 8 gauge distribution block then out to the M8/800 and to a fuse panel such as Amazon.com : Blue Sea Systems 5025 ST Blade Fuse Block - 6 Circuits with Negative Bus and Cover : Auxiliary Fuse Block : Sports & Outdoors. Or take the 4 gauge p/g that's ran into a 4 to 8 gauge distro block so the amp still gets 4 gauge and 8 to the fuse panel. What I'm not 100% clear on as well is what's the proper way to ground the fuse panel since these boats have a common ground or should share a common ground with the stereo system.
Of, should I just run new lines from the batteries back to the fuse panel and call it a day?
