- Raleigh, NC 27614
- 242X E-Series
Below is a video with installation instructions for Cobrasteeering on a 2016 242X. I found the directions that came with them confusing and lacking in high resolution images. Hopefully this video will help you install these.
What you will need
Allen wrenches 4, 5, 8mm
Sockets: 10, 12, 13mm
Crescent wrench 10mm
You will end up with 8 parts extra (assuming you also add the extra tie rod).
1 tie bar bolt from the gate
1 tie bar bolt from the rudder
4 bolts from the gate hinge points
2 bolts from the nozzle (the underside bolt)
Hopefully you find this helpful.
What you will need
