I think its a Connext Issue. Mine is off quite a bit as well (not that bad though) and is showing lower than actual hours, however when we took it to the dealer for the 10hr service (Connext said it had 1.8 and 3 or something like that) the dealer confirmed that a) The motors had 9.8 and 9.9hrs and b) They had no idea why the Connext was incorrect. Evidently the real hours data is still in the ECU and there is a sync problem with the ECU and Connext.
Will probably push the issue at a later date, but trying to give Yamaha some time to potentially update the Connext software and get the latest update prior to the end of Warranty.
Wow....I thought I was OCD, but you have me beat there!Did anyone find the fix for the engine hours discrepancy? When flushing the engines after every outing, I would even the engines hours up the the tenths, but now after my last outing, my hours are off by over six hours(about the length of the outing). I like things right and I know I didn't run around all day on one engine.
I was told by a Tech at BMC boats that the current model of the Connect system that is in the Our boat does not have a way to count engine hours from the ECU. In other words, the connect system is counting hours (somehow) but it’s not information that is coming from the ECU. Currently there is no fix but there should be at some point in the near future.I keep hoping someone has the answer for this. Does anyone know if the connext will reset to the accurate hours if I disconnect the batteries for a few hours?
That answer is yes. They should be rolling out a new software update campaign to fix what causes the discrepancy within the next couple of months and I heard they are working on a tool to set the engine hours. I have no exact date when all this will be rolled out but it is suppose to be coming.Wow....I thought I was OCD, but you have me beat there!
@tek4fun any ideas on if this can be fixed or corrected?
Do you think yamaha will allow customer to update? Provided the customer has laptop and firmware experience. Or do you think this is a dealer update only?That answer is yes. They should be rolling out a new software update campaign to fix what causes the discrepancy within the next couple of months and I heard they are working on a tool to set the engine hours. I have no exact date when all this will be rolled out but it is suppose to be coming.
I believe that these types of updates will always be dealer only. Just in case, something goes wrong with the update. It would be to protect the end users.Do you think yamaha will allow customer to update? Provided the customer has laptop and firmware experience. Or do you think this is a dealer update only?
