The number one thing for us to know is WFO rpm’s. The TR-1’s are rated at 8000 rpm at sea level.
Just hit me, you're a good resource for him, boating at a higher elevation. What are your RPM's?
The TR-1 engines are known to suffer rpm loss when over filled. Run the engines 6 mins and then immediately check the oil level, and be sure to screw the dip stick in fully when checking the oil. There’s a link in my signature about the proper oil level.
Screwing in the dip stick is important, as
@FSH 210 Sport notes. As I stated above, even my DEALERSHIP did a shite job with boat prep, and I had one engine overfilled when I got my boat.
Air filters. Do not buy new ones yet. Next time out pull them out and run the boat and see if there is a difference in rpm. If they’re clean you’ll see a difference of about 150-200 rpm.
Pay attention to the order of operations
@FSH 210 Sport is laying these things out. Get a baseline of RPM's before doing this. Seems like a "duh" thing, but I've done plenty of "DUH! I'M A DOPE!" things, and sometimes we do things without it even registering, so this is a great reminder
Spark plugs. Get a new set and gap them to .028” which is the minimum gap. .032” is the max. These engines eat plugs, get a new set and install them.
DO NOT assume they're gapped properly, just because "oh, they say they're pre-gapped". CHECK THIS. Our boats of all years and models seem susceptible to spark plug related issues, best to start off correct.
@FSH 210 Sport had a Proto or Stanley gap tester that was really slick, if you don't already have one, I'm sure he'll post a link.
Heys guys thanks for jumping in! I guess I should have mentioned that I wasn’t expecting to break any records or be the fastest guy out there. When I researched these units it was estimated at 40-45 mph so I figured I’d be somewhere around there, so although it performed great the top end just left something to be desired.
This is good info to know. More info is always better - we can separate the wheat from the chaff, and throw away the things that aren't needed, OR someone may spot something that's relevant that others may think is throwaway info. Oversharing, in this context, is a good thing, and having more info helps to develop a baseline for us, to help YOU.
I’m primarily 2000’ above see level so I’m sure that makes a difference. This was not purchased from a dealer and no service records were provided. So the basics like plugs, filters and oil change necessary or not just makes me feel better. When I checked oil it was on the low end but per the manual I didn’t run it for five minutes prior, so I will do that this weekend, I’ll also confirm WOT rpm.
Oil is an easy one to rationalize, but the other stuff may be hard to source, or even a waste of money if they're not needed yet. Best to save that money for fuel to use when having fun with the boat, not time sucks like maintenance
Best to check them first, as your boat isn't going to be dead in the water, if these things were in reasonable shape in the first place, and some things, like the plugs, have been spotted cheaper at local places like O'Reilly's Auto Parts, if those need replacing. Amazon is getting to be a "check first, and shop for prices" for me, and in some cases that I discovered, they're actually a LOT higher priced than my local B&M.
And I didn’t mean to clown thrust vectors or any other addition, it was just that there was so many posts and topics about it guys were making it sound as if it was impossible to navigate with out them.
There's only one specific member here that gets truly butthurt about such things, but I'm not going to say Beetlejuice 3x. I get what you're saying - I just try to add to the info people have, and WITH a steering enhancement, I hope to steer people (HA!) away from throwing money at ANY of them UNTIL they're comfortable with the boat, and I wish more would temper their recommendations, but it's the internet, whaddayagonnado?
My specific use case makes them super useful for me, about 20% of the time. For the other 80%, a big nothingburger. That 20% though, hooboy! I just tend not to go to that one restaurant on the water. It helps that they suck, so we don't stop there as often by boat. You already got a feel for life without them. If there's someone local to you that you spot, ask them if they've got them. Make a new friend, that's what I think boating is about. See if you can test drive a steering enhancement system before buying. You might just save a bunch of money.
