'22 AR195 - Clear Hose Lying Loose in Engine Bay
Bonfiggy
Oklahoma
AR195
Hey folks,
Doing some pre Labor Day checks on everything today to get it ready for the holiday weekend. Saw a clear hose, with red/blue lines on it, lying loose in the bottom of the engine bay. Can't figure out if it came loose from something, or if it's being hiding out under there the whole time (21 hours).
Any idea what this is and where it should go?
Thanks
Probably a cup holder drain hose that fell off. Likely one of the rear cabin cup holders.
To close the loop on this if anyone else runs into the same thing. Definitely the drain hose for the stepover seam. The drain is right above the engine and flows through the hose out to the transom seating area. Pictures for reference.
