Livi0411
- Dayton, Ohio
Doesn’t list my 2018 AR240 as a fit...X and AR’s tower structure looks the same, just diff bimini’s.
That is a CRAZY good deal...!Go under rack type and you can order a specific type a rack. They have a lot of different optionsView attachment 99691
@mattschepker
Look forward to your comparison on the fit of the ZUP board in the Bulletlines rack vs the Monster rack. Also quality comparison?
You got the 2-3/8 mount, correct?
Abe, I'm confused.....dont you have the X model? If so, did it not come with the swivel board racks?The catalog calls them wakeboard racks. Do they hold surf boards as well? Or, the Zup board? My surf board is much thicker than a wake board (and thicker than some surf boards). My Zup and surf boards both fit in my krypt surf rack, so they are standard size.
Are all 4 slots the same size or mix/match?
@jcyamaharider
Correct. The date the thread was created, I still had my SX210.Abe, I'm confused.....dont you have the X model? If so, did it not come with the swivel board racks?
@mattschepker
power coated. I did slide the surf surf rack on both sides of the footholds on the zup board and it fits nice. Once I get it put together and use it I will give you a better comparison.Mine do not touch either but the gaps are identicle. Tighten the top a little bit loosen the bottom from pic 1Just mounted my Monster Surf/Wake Combo rack with the 1-7/8” swivel mount. Not sure of the fit...doesn’t seem right. Dealer confirmed rear bar on tower for my ‘18 AR240 is 48mm. Anyone confirm the fit compared to there’s?
