250/252 Port side storage (head) door alignment
VitaminSea
Central FL
252SD
I have noticed from looking at a few late model (2024-2025) 250/252s that the port side storage door doesn’t appear to be aligned correctly; said another way the vertical gap is not consistent. Example below.
Has anyone experienced this and if so, is it the result of alignment or perhaps a bad mold?
Furthermore if you took delivery of a boat and noticed this, how was it remedied?
Not my boat, but a friend just got a '23 252 with this same issue that I noticed. He's fine with it for some reason, I didn't have a chance to look too closely into it, but it seemed like there's a hinge issue, or placement, which would seem to be a mold issue
I don't think he will be addressing it, but whenever I get a chance, I will be taking a closer look at it
I bought a ‘25 252SD and the door didn’t fit nearly as well as the one pictured. I pointed it out when I took delivery and they tried to adjust it and offered to replace it under warranty, but I told them I’d see what I could do first. If you look closely at your picture, you’ll notice the top of the door isn’t flush with the adjacent surface either. Again, mine was much worse.
There was a tiny bit of adjustment with hinge pins, but not nearly enough. What I’ve done so far was to open the door and place a 3 or 4”piece of 1” PEX (?) in the drainage channel at the top and towards the front of the door. Closing the door lifts the top of the door, making it flush with the adjoining surface and moved the bottom of the door into position. The door fits really well now and I’m just waiting to see if the summer heat helps to reshape the door. My boats in storage, but I can add a pic later if that’d help.
We just bought a 2024 252s and our door also looks like that. Haven't addressed it yet. Been taking care of other, more important quality control issues like loose grab rails, loose interior side panels and 3 non op USB charging ports.
Thanks for the feedback thus far. The dealership knows it’s a concern of mine. Wanted to know how others have remedied.
Had the exact same issue with mine (2024 252SE). The dealer tried over and over to adjust it, did get it a little better. But ultimately ordered a new door from Yamaha and that is the only thing that fixed it (under warranty of course).
Finally looked at mine today. It’s barely off, not near as bad as the picture you posted above, and honestly I’m probably not going to worry about it. What I think is the problem is the rubber stopper at the bottom of the door, below the handle. You can adjust the rubber stopper in or out, and from factory they are installed too far out (or too much length) so when you close the door that rubber stopper pushes the bottom of the door out and maybe it warps the door slightly. I shortened mine so we will see if it does anything, but for now the door functions as it should, and I’m not gonna take it to a dealer during boating season! 🤣
