jeremy0011
- Fuquay Varina, NC 27526
- X
If you have a new tower with a tow point that looks like the one below, and want to mount a LED (both 12v wired or battery powered) light on it I have a solution for you. I have made an adapter that slides over the top rounded portion of the tow point and gives you a flat place to mount the light. The adapter looks OEM.
The battery powered Navisafe LED and Adapter is $174 shipped
The 12v wired Attwood LED and Adapter is $149 shipped
Installation is simple. It’s a loose press fit so you can either drive it on with a dead blow hammer or heat it up in the oven at 425 for an hour and slip it on. If you have the Navisafe LED just attach the base to the installed adapter and you are ready to go. If you have the Attwood LED you then use the adapter as a guide to drill the tow point to run your wires.
Let me know if you have any questions.
