Evil Sports
- 91 North/75 South
- SS
Have um and love um
Anytime. I'm not convinced that using the brackets on the rear (as seen in my photo above) is the way to go. I'm starting to see some bend in my tie down tabs on the trailer. The nice thing about this type of mount is it gives a better down angle for the boat buckle. Others have mounted the buckles directly on the trailer frame by bolting through. The strap then is more at an angle and has to twist some. I may do this if my mounts continue to flex. I might be ratcheting them down too tight too. I noticed some spider cracks around my rear tie down eyelet.Another DUH for using on the bow. Can't believe that never occurred to me. Staring at me every time I launch the boat! Thanks for the pics @jetboater4life.
And they are strong!! A few years back I was rear ended while towing the the lake and the boat buckles kept my boat from bashing the tailgate. The guy who rear ended me was towing a boat with standard straps and his boat ended up in the back of his truck with the bow on the roof. Can't go wrong with boat buckles!
Wow! Any pics?
effer....Here's a coupon for a free set.....
Wishful thinking!
Ditto! Did this first with my LX210 as the bow would bounce on the trailer. Not sure if the SX 230 bow would bounce....because I put a boat buckle on the front from day one!I took the safety cable bolt to the hardware store and got one about an inch or so longer. Then I mounted the boat buckle to the opposite side from the safety cable. Rock solid.
I like your installation. I think that is what I will do if I continue to see stress on my tabs (the ones connected to the trailer, not the brackets I used to mount the boat buckles.)Member tips thread that has photos too:
https://jetboaters.net/threads/boat-buckle-installation.888/#post-11247
Also is #1 in the modifications section of the FAQ!
Yeah....I didn't like the tab attach point....seemed like the weight of the boat would bend them right off eventually (or in an accident). Drilling the frame was easy and you just pop off the end cap to attach the lock nut inside.I like your installation. I think that is what I will do if I continue to see stress on my tabs (the ones connected to the trailer, not the brackets I used to mount the boat buckles.)
They should be on your trailer.
