Geiger41
- Egg Harbor Township NJ
- Boatless
- NA
- Other
- NA
Thoughts ??
Only problem I see is that they do not have any boat templates already ready for order. They want the buyer to make one.
I suppose the easiest thing to do would be to send them the existing carpet for a template. So how much does this stuff cost? Or do I have to Google that?
This stuff lays flush with all the edges so it will be different than our carpet. I believe there are no gaps.
For whatever reason, from my previous research on the product, I seem to remember the edges are cut at an angle so it lays flush above the curve.The edges on my boat are all rounded up the side walls....are you saying the edges are rounded to fit? Does anyone have this stuff installed????
You should order it from there, it will probably cause that forum to shutdown for a month.http://yjbstore.com/product_info.php?manufacturers_id=40&products_id=709 here is for my boat A little steep in price
I bet if you contact DECKadence directly, http://marineflooring.net/, they would have the templates, I doubt Brian has the ability to cut the flooring.HA that site is actually the only site that I see that has the Yamaha Boat templates already ready to order. Considering making the buy but gotta do some more research first
Actually you should start a group buy thread for it. That would definitely shut it down..You should order it from there, it will probably cause that forum to shutdown for a month.
