haknslash
- Lake Martin, AL
- Moomba
- Other
Here is how I'm building my DIY surf gate for my AR192. I know, I know, delayed convergence supposedly doesn't work well fighting against the jets but I think we can explore it further. I'm not aware of anyone trying this on a single engine jet 19' Yamaha yet since there is considerably less jet wash to deal with and it doesn't take much listing to clean up the face of the wake. I should hopefully have this completed in time for testing at our gathering next weekend.
For reference I'm using this suction cup grip handle. It's made from metal so no worries of the cheaper plastic ones cracking.
These are the stainless steel heavy-duty L-shaped brackets I'm using as bracing for the starboard (HDPE) wedge I will cut out later on once I have my pattern/templatre made from cardboard.
In order to mount brackets to the suction grip handle you must drill holes in the grip. Some people would pry back the rubber and try to drill the holes but this can easily damage the suction cup from the drill bit hitting it. i'm going to show you how to disassemble the grip so that drilling will be safe and easy....
Once you remove the C-clip and pin the flip handle can be removed allowing the suction cup, spring and shaft to come out from underneath the grip....
I drilled some extra holes in my brackets so that they would line up with the grip...
Stainless steel bolts and lock washers used for securing the brackets to the grip handle...
Install bolt and lock washers from underneath the grip handle where the suction cups go....
Should look like this....
Then install nuts and lock washers on the bracket that the C-clip would face. I don't recommend installing both brackets at this point because it will be explained further down.
Now the fun part ! Reinstalling the flip handle to the suction cup, spring and stud....
Install remaining nuts and lock washers to the other bracket. Both brackets installed and it should be looking like this....
Initial mock-up. I plan to use the underside of the swim platform instead of the side of the boat to apply the surf gate. My theory is that this will allow me to get the starboard just aft of the transom more so than using the side of the hull. It also allows the gate to sit down completely submerged in the water hopefully giving me more of an effect on delaying the water as it flows behind the boat....
Bracket "L" ends are flush with the side of the hull. I will add cross bracing and mounting for turnbuckles.
