- Raleigh, NC 27614
- 242X E-Series
First of all the reverse maneuver will not remove something wedged in the impeller - it is primarily a weed removal trick. Sticks, bottle caps, frisbees, golf balls, etc....will require manual intervention. But it is always the first step I use in clearing something from the pump. If it fails, then pull the clean out ports (if you have them). Lastly, pull the pump. You really should never mess with the intake grates as this opens up another can of worms (namely intake cavitation).
HOW TO DO IT:
1) Put it in reverse, and get the boat moving backward (faster the better)
2) Kill the engines (pulling the lanyard off is the fastest way)
3) Put the throttles into forward (this allows water to be pushed directly into the exposed jet nozzles and force stuff in the tubes back through the grate, or off the grate).
What I do is grab the lanyard with my left hand, put it in reverse with my right hand, get up some speed, yank the lanyard with my left and instantly put it onto forward with my right.....works 95% of the time. The only time it didn't work for me that I recall was when I sucked up a flexible frisbee...and it was lodged hard in the intake grill.
This works great for weeds, sticks etc.
HOW TO DO IT:
