Geoff Cooper
- Thailand
If you follow Julians thread on replacing reverse gate cables he describes how to remove the Binacle and removing the cable at the Binacle end it's quite straight forward please revert to that as i don't think it's necessary to repeat the process again to show you how to lubricate the cables with ease so i will take it from there with some simple Photos and an explanation of how i do the job every few months, It keeps the cables nice and free as it's near impossible to lubricate where they connect to the jet housing apart from grease the outer part where it exits the sleeve, ok here we go.
I tape a hook onto the screen surround just above the Binacle just to stop it sliding down, I get a plastic bag the kind with 2 handles that can go over the hook easy, You can buy a pack from any Supermarket the size about 10 x 8 or bigger if you like but no smaller, Pull the carpet back just in case we don't want any accidents.
After removing the connectors locking nut and the rubber grommets from the cable oh make sure you count the turns when you remove the connector so it goes back the same and put them in a cup holder so as not to loose them, Locate the bottom corner of the bag and gently push the inner cable through the plastic bag right in the corner.
Slide the bag down the cable until it goes over the outer cable and the recess which secures the outer cable in the Binacle, Put a small cable tie and fix the bag to the outer cable using the recess the cable tie will fit good in there and make a good seal.
You should now have something that resembles this, The remainder of the bag which is below the cable tie wrap some masking tape around to make sure there's no leaks and to keep thing's tidy.
Ok it should now be looking like this.
Ok gently slide your fingers up the loose bag until it's just near the start of the outer sleeve, Place another small cable tie to hold the bag in position and again run some masking tape around, You can now see the effect you get, You have a small container to put your oil in and 2 handles to hold it in place on the hook, Ok lets go and work on the other end.
I use a plastic top from an aerosol or something similar cut a v shape into it and cut it down to size to fit under the reverse gate cable.
Ok thing's should become clear now, Pull the rubber seal down to the edge of the plastic as when the oil comes through it will hit the seal and go into the cup, You only need to use a couple of tablespoons of oil and put it into the bag at the helm and just leave it overnight and let gravity take it's course you will see how it works by the oil in the plastic top in the morning and you can add more if necessary.
I adjusted the bag here to show you a better Photo of the inner but it will give you a container about the size of a cup, Just put a couple of tablespoons of oil in make sure it's above the outer cable and leave it to work, I do it every few months and i just changed my first cable on a 10 year old boat that gets plenty of use.
I just use a normal vegetable cooking oil it's thin and it works well and it's only for lubrication, 1 bottle will last you a lifetime, I don't recommend using the oil that comes out of the cable for cooking after maybe not a good idea, Oh don't forget to put the rubber seal back in place on the reverse gate cable at the jet end, Put the cable back together at the Binacle don't forget the amount of turns for the connector and job done, It's not a difficult job just take your time and you will enjoy doing it, It may save you a lot more work and expense at a later date replacing cables. Good Luck.
Oh here's a tip for you.
If you ever have to replace a reverse gate cable before you dispose of the old one remove the rubbers from the Binacle end of the old cable as they will be like brand new and you can replace the old rubbers at the jet end of the other engines reverse gate cable as they will be showing signs of wear, There exactly the same size.
