Glassman
- Redondo Beach, California, U.S.A.
To be sure I wasn't re-inventing the wheel here, I did a quick (emphasis quick) search and found this thread:
https://jetboaters.net/threads/fuel-additives.4494/#post-76561
So I went searching the vast inter-web and found this:
http://www.lewrockwell.com/2014/09/eric-peters/evil-ethanol/
And the link within the article above:
http://ericpetersautos.com/2014/09/18/curb-evil-ethanol/
Let's just say I've set out on a task to find the best way to reduce the harm ethanol is, can or may be doing to my power toys and vehicles.
I've tried a bunch of additives over time and some seem to work and some are so-so.
Recently I purchased one called Ethanol Defense :
http://www.bellperformance.com/fuel-treatment/ethanol-defense
I got it primarily for my old car....it seems that the way the gas tank is constructed - aluminum baffles welded along the bottom - it is especially susceptible to damage caused when the water that ethanol blends eventually attract and absorb sits at the bottom of the tank and corrodes the welds and the baffles eventually break loose from the pressure of the gas sloshing back and forth during my high speed turns .
Anyway, I'm in the process of evaluating this stuff - and I realize it may be a moot point since the car is a daily driver and I burn the gas faster than it can do any damage (but they also say it increases gas mileage and that's what I'm looking for too).
The other reason I want to learn more about additives vs. finding real gas with no ethanol (very scarce here in this state) is because of the boat and off-road toys. I would like to avoid problems with ethanol mucking up all the rubber parts, hoses, gaskets, etc. I've already spent too much on carburetor rebuild kits for my liking.
So, are you all concerned with the increase in the amount of ethanol in our fuel supply? Do you have access to, or run ethanol free gas?
What's the scoop?
What's the scoop?
