Perhaps my voicing of some politics was inappropriate, and for that I apologize. I'll keep that off this site from here forward.
Politics aside, I'm sorry for using "big" words. That's just who I am, I always try to be as accurate as I can given my career choices and the hobbies I pursue. I'm not trying to talk over anyone. If you think that my statements are amusing, enjoy the entertainment. But if you think the term "reciprocating parts" is too big a term, sorry, I can't bridge that gap.
I dont appreciate when my words are distorted or taken out of context to imply I am giving bad information. E10 is not the devil's fuel, it's a fuel that is simply inferior to E0. The manner in which it was brought to market was shady, and the best interests of the consumers were completely ignored.
You guys are talking about custom tuning, which is great, except you were comparing my information about original production equipment to your custom tuned information without providing the proper context and then saying I'm wrong...not very cool. Maybe I was oblivious, but I never saw any thing about custom tuning brought up in this thread.
Jgorm, when I say that ethanol is a slower burn rate and lower burn temp than gasoline, explain how that is inaccurate?
Please explain how a production automobile that is production tuned for e0 losing 10% on e10 gas is inaccurate. I'm not talking about a race tuned vehicle where you can skirt warranty, skip bad gas padding, engineering safety factors, and ignore EPA emissions concerns. I'm talking about original production ecu programming for e0, and then running on e10. Ive seen it on dynos, and I've seen it at the track in et's and trap speeds. That is the condition for millions of older cars still on the road today.
Jgorm, while you need additional fuel flow for e85 to make the SAME power, the additional amount depends entirely on how aggressive or conservative the original factory gas tune was, and how aggressive the E85 tune you use is as well. You might need 33% more, you might need less, especially depending on stock timing, compression, and stock programmed AFR...hence my statement of AT LEAST 10%. In a fully tuned gasoline vs e85 comparison, yes, you need 33 percent more flow. I guess my assumption that the statement I made regarding ethanol being 2/3 the energy density would be noticed was incorrect.
Gmtech16450yz, as to the statement that a vehicle tuned for e10 will have a different stoich, and run worse on E0 - congratulations, water is wet. Yes they have different stoichs, and when you run any fuel on a tune designed for a different fuel it will not be ideal. Manufacturers had to change stoichs when they realized the majority of available gasoline was not what the engine was programmed for. Take the same vehicle and properly tune it for both E10 and E0 and then use the correct fuel, and guess which comes out on top. Fact.
It's TRUE, modern flex fuel vehicles can monitor combinations of e85 or gas and use different stoich based on the fuel content. It's been that way for years. It doesn't change the fact that when E10 was forced into use, vehicles on the road weren't equipped to use it, and neither were manufactures ready either.
Gmtech16450yz, I see you can find and paste stoich values for a production vehicle. Maybe you could take a screenshot of the stoich values for any of our boat engines instead? That would settle the original discussion real quick wouldn't it? From what
@SamCF says regarding different fuel testing it sounds like they're tuned for E10.
Your info isn't wrong...given the context of custom tuning. That being said, very few of us on this board use it. It's the same with automobiles, there are millions of people who either never knew or cared but were adversely affected by e10 anyway. There are even less that took it upon themselves to come up with a solution.
I do agree that current technology vehicles and custom tuning can address the problems and somewhat close the gap between E10 and E0, but this is a recreational boat forum, and as far as I could tell a recreational boat thread.
Has any of us taken our boat into a shop and yanked the engine and strapped it to a dyno? Even if anyone had, what's the relevance in comparing custom tunes at all in this discussion if we are trying to figure out what Yamaha's stock configuration is?
