mrodz123
- Haulover, Florida
Greetings Jetboaters! Long time reader, first time poster. I wish my first post could have been something less serious, but alas I could really use your advice on this one. Last week my fiance and I went out for an evening cruise to watch the sunset. We usually head out for dinner on the water once the sun sets, on our way to the restaurant though we had the awful luck of sucking up someone's rope that was randomly floating in the channel. I immediately heard the sound of my engine grinding, so I idled my way out of the channel, cut both engines, and opened the clean-out plugs hoping I had just sucked in some seaweed, only to find that it was a rope, and it was very badly wound around my impeller shaft of my portside engine. I went at it with my knife but to no avail, it was impossible to remove it all. So we decided to head back to the marina with the portside engine on idle and the starboard engine at low speed. We tied up the boat and left it overnight for the marina crew to put away in the morning, when they would be able to flush my engines and do all that good stuff.
Well, it gets worse. I got a call from my friend at the marina in the morning and he had very bad news. He said the rope had damaged the seal, and my engine compartment had taken on a bunch of water. He pulled the boat out with the forklift and drained the water, and treated the engine with CRC and left the lid open to dry it out before putting the boat away in the indoor storage. He also mentioned that neither engine would start. I went to the marina as soon as I could and took a look. It looked like it sure did take on a lot of water. The engine compartment was wet up to the carpeted area on the sides. I noticed a little bit of water inside one of the air filters, but I have to assume both got wet, just maybe one dried faster. Naturally, the engines would not start just as he said. They both turn over, but just wont start and the check engine message comes up on the dash. I checked the oil, and it seemed to be fine (no milkiness). I wanted to be sure that it wasn't a battery problem, so I hooked up the marina's battery charger and that didn't help. I also added fresh gas with a little bit of STABIL marine, and that also did not help. I read on here that it would be a good idea to pull the spark plugs and check for water, and to also try to start the engines without the plugs and see if water comes out. Well no water came out when I tried to start it up with the plugs removed, but I could see it wet inside when I shined my flashlight into the plug sockets -- I don't know if that is gas, or oil, or water, but it looked wet inside. I'm all out of ideas now, and I'm worried sick that this is going to be a total loss. I called a nearby Yamaha mechanic dealer that services boat on site, but with it being Christmas and all, they told me they probably can't get someone out until Wednesday, so I am really very worried. Any other ideas? Am I in trouble?
Edit: it's a 2013 Yamaha AR210. We bought it new back in 2013.
