Welcome to Jetboaters.net!
Do you have the original fuel sending unit and does it read properly? If it doesn't read well, you might want to just get a new sender and it will come with a new gasket....
Not to be rude but make sure you install in the correct orientation as it only goes one way. My 08 was leaking at gasket because it was installed wrong. I spun it one bolt pattern to the right and it aligned correctly.
