FLJetBoater
- 242 Limited S E-Series
Out for the farewell voyage on our 2014 after picking up a 2015 on Thursday.
Driving along yesterday in Tampa Bay and all of a sudden boat feels sluggish. Within 1 minute port engine cuts off. Run back check engine compartment and it’s almost entirely full. Bilge pump is on but doing nothing. Shut stbd engine off. Water still coming in...long story short we ended up at Macdill AFB. Boat took on about a foot of water in the cabin. BoatUS had to pump it out before they could tow back.
pro tip....if you have water in your boat for any reason it is considered salvage and BoatUS does NOT cover it. Pumping is $125/ft. So nice bill that hopefully insurance will cover.
Get back to dock, pull boat onto trailer and up the ramp a bit. A little bit of water came from the port exhaust (the boat was heavily listed to the port so could have got in there) but then nothing else at all. Pulled the drain plug and let it drain for a good half hour. The cause is still unknown there didn’t appear to be anything obvious.
This morning...pulled lanyard, pulled spark plugs. Turned engines and blasted a whole ton of water out, more towards rear. Blasted until no water came out but if I look down the tubes I can still see water there. Any suggestions how to get the rest out if it’s not being blasted out by cranking the engine?
Also when cranking the check engine light came on. Suppose this could be normal because there’s no spark or it’s not starting?
I have a feeling this boat is headed for the dealer.
