fatboyroy
- Sebastian, FL
- FSH Sport
change oil asap unless you want chocolate milk next time you cruise
ya, my boat was running fine. I got to the cove I was heading to and opened the ski locker and it was full of water. I had forgotten that day to put the internal plugs back in. Actually probably saved me from engine damage as it gave more space for the water to go.This is kind of what I’m thinking. Something after the engine, either cooling water exit line or exhaust. I never got an overheating warning so unlikely it was cooling lines before the engine. I think it would overheat before swamping the engine compartment with water.
Unscrew and pull up that cleanout hatch. I bet you have broken exhaust clamp.(s)Out for the farewell voyage on our 2014 after picking up a 2015 on Thursday.
Driving along yesterday in Tampa Bay and all of a sudden boat feels sluggish. Within 1 minute port engine cuts off. Run back check engine compartment and it’s almost entirely full. Bilge pump is on but doing nothing. Shut stbd engine off. Water still coming in...long story short we ended up at Macdill AFB. Boat took on about a foot of water in the cabin. BoatUS had to pump it out before they could tow back.
pro tip....if you have water in your boat for any reason it is considered salvage and BoatUS does NOT cover it. Pumping is $125/ft. So nice bill that hopefully insurance will cover.
Get back to dock, pull boat onto trailer and up the ramp a bit. A little bit of water came from the port exhaust (the boat was heavily listed to the port so could have got in there) but then nothing else at all. Pulled the drain plug and let it drain for a good half hour. The cause is still unknown there didn’t appear to be anything obvious.
This morning...pulled lanyard, pulled spark plugs. Turned engines and blasted a whole ton of water out, more towards rear. Blasted until no water came out but if I look down the tubes I can still see water there. Any suggestions how to get the rest out if it’s not being blasted out by cranking the engine?
Also when cranking the check engine light came on. Suppose this could be normal because there’s no spark or it’s not starting?
I have a feeling this boat is headed for the dealer.
Yeah it’s nasty color, 2.5 gallons total. At first it was pure water then started into the chocolate milk stuff.From the crankcase? That seems like a whole lot which means you had a lot of water mixed with the oil.
I assume you have the 1.8l engines right? Same as mine and I recall drain about 4-5 liters when I changed the oil.
What color is the oil? I’m guessing milky coffee color?
Still hard even with new oil. Think battery is toast have to charge it up or get a new oneYikes! That’s likely the reason why it was hard to turn over.
I just had all the cooling and exhaust clamps replaced by the dealer about a month ago. But one could have come looseWow, sorry to hear. Glad you and your family made it back to safety.
Did you check the exhaust hoses under the clean out hatch? I was shocked to find my clamps completely rusted through when I was tuning it up during the off season.
Per other’s this is a common issue in salt water boats and can cause the boat to take on water.
Good luck with getting the engines to turn over.
Thanks I appreciate it. Everyone here is great!I wish I lived near by @FLJetBoater . I would donate my day helping you get it running. Judging by the character of people here, I am sure I am not alone.
17 years of Yamaha jet boating and never needed them. I DO have hose clamp pliers on the boat ($10 on Amazon for 3). I love doing mods....but this one just doesn't have the need from my perspective.After reading all these horror stories here on the forum, I'm definitely adding shutoff valves to my intake hoses. I'm going to try and come up with a way that lets me know they are open before I can start the engines. I know I can just look, but when you get to be my age, you can get CRS. I have it.
It would be great to be able to have the switches in the valve that act like the lanyard cutoff switch, which won't let you start the engines if you forgot to open the valves.
@FLJetBoater Are/Were you able to inspect the plastic manifold as @bthessel has suggested? I know that will be difficult without running the engine, but when the time comes....I had a similar thing once, the plastic manifold on the port engine where the water comes out of the engine was cracked and it pumped the engine compartment about half full of water before I noticed (also found out my bulge pump had went bad that day) thankfully I had my ballast bag pump and used that to pump out the water before limping back to the ramp.
Which part are you talking about exactly? Where it exits the hull or the engine?@FLJetBoater Are/Were you able to inspect the plastic manifold as @bthessel has suggested? I know that will be difficult without running the engine, but when the time comes....
