Help needed
Bdog
Twin Cities, MN
AR195
Does anybody have any ideas what this cable is for? Brand new boat port side rear compartment looks like it has come disconnected from something comes from the battery? 19 AR195
I think that goes to the beer cooler... No, I really don't know. Is there anything not working?
I tested everything... could it be the harness for a optional amp or something for an accessory speaker? Everything works! Lights, courtesy lights, anchor, nav lights, bilge, horn.
Does your bilge pump work? Thinking it may be a hot wire to that.
It’s for the cl-2. Lol
Sorry I couldn’t resist.
Can you find a Service Manual a match-up the connection that has only Blue and Black leads? It might be something like the Cruise Assist which only testing during a sea trial would confirm.
based on the routing the cable appears to take it looks like it heads up the port side towards the port compartment but I can’t find an area where it would connect to and after a quick internet search it looks as though CL-2 is a speaker wire or other low voltage connection. Haven’t tested the radio yet though after being on the lake Saturday.
Still nothing...anyone else have a 19 model AR195 and could go have a peek and see if they have the same cable floating around? Portside compartment next to bench seat comes from battery and heads up to port compartment-zip tied just under lip of seat. Everything works...in garage anyway.
Bump- Anyone else have this free floater cable in the battery compartment- just wondering what it is everything works correctly.
Anything on this feature comparison list that might exist between Yamahas 19-footers:
Perhaps mother Yamaha does this to add or eliminate electronic features between its 19-foot models?
Interesting could be the answer! Cruise assist is also working as well as no wake mode. Must be a speaker wire?
I have a '19 AR195. Since our names are similar, I will be happy to look at mine. Unfortunately, it is in a slip and I won't see it until Thursday evening. I will take a look then.
I stuck my head in the port compartment of my '17 AR190 last night and didn't see anything that looks like that.
I'll check again tonight with a more thorough look this time.
Appreciate that!
  • Like
Reactions: Gym
