Impeller Housing - Bad after approx. 40 hours and 6 months?
zbell305
Hi all,
I have a 2018 AR210 with ~300 hours on the engines now. Earlier this year (January 2023), I replaced both impeller housings with the local dealer. I just brought it into the dealer for an unrelated engine issue, and when checking the impeller housings, they are saying that one of the housings needs to be replaced again. Since it was installed in January, I have added about 40-50 hours to the engines at max. I used the boat close to every weekend (saturday and sunday), with 1 or maybe 2 weekends where I didn't use it. I flush it on a rack every sunday night after using it and it is stored in a dry rack during the week. It seems implausible that the housing could go bad this quick. Does anyone have any insight or thoughts they could share?
Thanks
Zach
How are your zincs?
How are your zincs?
That’s a good question. I’ll have to ask the dealer , I’ve never pulled them to check. I flush it on a rack religiously.
My 2005 had no zinks and it was used 80% salt water only left it in the water a few times for a weekend and a dozen or so overnighters. Never a problem with the wear rings. Sold it in 2018 with 300+ hours jet drives looked like new. My 2017 was moored by the previous owner nut sure how long but minimal deposits on the 70 hour boat. In 2020 both wear rings swelled and needed to be replaced. There are different grades of stainless steel I wouldn't be surprised at some point if the manufacturer changed materials to lower costs.
Sometimes they use a plastic wear ring, what material is yours?
Is there much debris in your water?
I'd want at least a picture or see it in person,especially if you weren't having any cavitation issues
id have to ask about the wear rings - everything was done with OEM parts when they were replaced. There’s a good amount of debris in the water at times, but I can usually tell if anything at all is in there and either pull through the cups or dive under and take everything out from the grates. I even dive under when it’s anchored to check the grates. So things get sucked up from time to time but it never stays there
