LED Trailer Lights
Jilly Ruby Jane
Bayliner
SX192
LED Store 6” oval red LED trailer tail lights, it has 10 super bright LED colored lights that can deliver full visibility at night. Submersible in water and waterproof
212s
1000 Islands
That connects to the connection plug between your truck and trailer. Should be brown for both brake lights, yellow and green for turn signals and white for ground.
Just to clarify:
brown is for all marker lights (at night)
yellow left turn/brake
green right turn/brake
white ground
My 2 cents - I always unplug as I'm prepping the boat for launch so the bulbs are cold when the trailer hits the water. This ensures my vehicle is protected from any potential shorts. This also means the surge brake lockout is not energized, but I use a magnetic lockout pin to release the brakes for backing into the water. Been doing this for years so it's routine.
Jane305
Grady White
I recommend Wellmax LED, Energy-efficient, and cost-effective.
You could see some review here
SCP1
DeForest, WI
Just to clarify:
white ground
Magnetic lock out pin? Can you show us what you are talking about?
SCP1
DeForest, WI
Not saying you can’t have a problem but since I switched my lights to LED I have not had a problem leaving them plugged in.
zipper
Boston Whaler
212s
1000 Islands
SCP1
DeForest, WI
@SCP1 Yup, bought a two pack of the orange ones in case one breaks or is lost. The magnet holds it in securely so no fussing with the stock key shipped with the trailer that is designed to fall out when you pull forward. I pop it in as soon as I unplug the light cord.
Thanks, so do you just rap the cord around the trailer then so end of the cord stays dry and high?
212s
1000 Islands
You could, I just put the cord in the holder beside the tongue. I'm not too concerned with it getting splashed, just don't want it dunked when it's live and connected to the truck.
RobbieO
Sacramento River Delta
212SE
Ok guys I’m done replacing bulbs looking for a full LED replacement for both sides. Thinking like take the old one off and smash it and put a new LED unit on. :winkingthumbsup" Do you guys have any recommendations on a preferred vendor or part number?
I just purchased submersible LED trailer lamps from etrailer.com. My new Shorelandr trailer (2021) came with incandescent bulbs which are not even sealed. For $60, you can replace both rear lamps, and the rear marker strip with sealed LED's. I was told by the dealer to leave my trailer plugged in when launching because I need to keep the brake bypass solenoid active. I was told my trailer had sealed LED's so I shouldn't have any issues. When I checked the lamps, I was appalled to see bulbs that I could touch with my finger. $5k for a trailer, and they don't even give you LED stop lamps. CAF.
Joatmon
Estero, FL
Scarab
255 SE
I can give you my recommendation on the specs you should look for based on my experience. Definitely LED instead of incandescent. Look for submersible lights with tinned wires. Not sure if you launch in saltwater but untinned wire will corrode because the saltwater permeates the insulation.
I know most don’t but I always unplug before launching. Old habit. Before LED’s I used to coat the incandescent bulbs with clear silicon rubber and this reduced the chance of the hot bulb popping.
To back the trailer when I unplug the lights I would plug in just the last connector for the brake. Just turn the flat plug at a 90 degree angle. Since I launch in saltwater I changed to a military plug that won’t corrode. Got tired of cleaning the corroded plug every time. Now to bypass the brake I just stick in the hitch coupling locking pin to the prevent the coupling brake from collapsing. Etrailer is a good source for LED’s. Most suppliers don’t know if their light wires are tinned or not. Not an issue if you are only fresh water guy.
RobbieO
212SE
Thanks...I'm a fresh water guy....already converted my lamps. Got them from etrailer, and they are excellent quality.
Yamahaul
Gainesville, FL
195S
anmut
You can buy plug and plays from Shoreland'r - first mod I did to my setup. $55k boat comes with lamps from 1983. LAME.
kgower
Buford, GA
222SE
WV Hillbilly
Charles Town, WV
195S
found them for $20 less at www.easternmarine.com
LED is the way to go. I have them on all of my trailers, toy hauler to boat. I put IP67 on anything other than a boat/jet ski trailer and IP68 rated for the latter. 67 gives you dust and submersion protection for 1 meter for 30 minutes, 68 gives you fully sealed to 10 meters or no damage if water does intrude. IP68 is a bit more spendy.... but lasts longer.
212s
1000 Islands
Yup I'll be ordering a set from my local dealer this spring to replace the stock bulb set - they're not terribly bright during the day and I want brighter brake lights. There's a kit available that has the left/right lights plus an LED center marker replacement. The rest of the marker lights on the trailer are already LED. Everything is plug and play in the kit - the part number is TA0126 per Shoreland'r
Tranquility Base
Here is what I got. It is an exact replacement for shorelander so you don't have to cut or splice any wires.
Shorelander 5110570 Submersible... Amazon.com: Shorelander 5110570 Submersible LED Left Side Tail Light: Sports & Outdoors
And
Shorelander 5110569 Submersible... Amazon.com : Shorelander 5110569 Submersible LED Right Side Tail Light : Boat Trailer Lights : Sports & Outdoors
Does the left side/drivers side have a license plate illumination light? From the pics on Amazon it doesn't look like it...
Edit: Read the questions on the amazon posting and the 570 has a bulb facing down for the license plate illumination.
jEt_jAk
SoCal
AR195
Yes it has illumination light as well.
SamAR195
I ordered these on Monday and they hit the deck Friday. Install was plug n play and I can’t believe how bright they are. Major improvement! The left side has a light for the plate and the right does not so make sure you order both part numbers.
