- SF Bay Area
- Limited S
So the weather has been sunny and hot on the weekdays / raining and cold on the weekends for the last three weeks. So much for boating or working on the boat but I am still getting what I can done. First unplanned task of today was installing a new hitch on my SUV. Pushing a trailer forward into a tight spot is a lot easier than doing it in reverse. View attachment 218007
View attachment 218012View attachment 218009View attachment 218010View attachment 218011
Today I sprayed some rust stop on the leaf springs and painted to the brake caliper and hubs on one side of the trailer. I also replaced the bearing buddies and grease (got to use my new tool to pack the bearings, it took a lot longer than doing it by hand but I feel it got everything). Finally i cleaned off all of the grease that slung onto the rims after I overfilled the old bearings and blew the seal. Not a great pic but there is not much to see. As usual it took a lot longer than expected but the second side should go a lot faster.
I’m not in a position to try to rebend /straighten the bottom rail of the frame to make it touch the boat and I can’t reuse the 2010 frame because the curve of the windshields is less steep on the 2017 frame. My original plan was to cut the ends of the top and bottom rails to fit and have two custom side windows made from plastic. Cutting the side window to fit was never in my plan, if it’s safety class like the the front panes it would likely just shatter. The only things holding my shattered window together were the tiny and frame.What is the amount that needs to be removed? I've seen diamond sanding blocks used for concrete, and I'm wondering if that might work, if the amount isn't huge. I've never used them, but it seems gentler and possibly less chance for breakage if sanding vs cutting.
No idea or personal experience, just offering ideas. Look for concrete countertop tools - I think there's grinder disks and blocks, not sure if the cost would be prohibitive either.
Likewise.I have a G8 and a G9 that I haven't used on the boat yet, lol.
I need to practice some more on my older truck before I move on to the boat. Once I have the confidence with using them on the boat I will move from hand polish to machine polish. Or I could just pay someone to do it for me, lol.
I removed the 2010 glass and replaced it with glass parts from a 2017 this weekend. As usual it took a lot longer than expected. This will be the first season in three that I can see through my front windshield.
I may fill the rear frame with glass or plastic if time permits. View attachment 218969View attachment 218970View attachment 218971View attachment 218972View attachment 218973View attachment 218974
Trick! And beautiful! You are rolling large!Another driveway boating Saturday. Cleaned the boat today. That is, washed out the interior, treated the upholstery, applied Griots 3 step system (compound the deep scratches, polish then wax the whole boat. Also painted the bat symbol and switched from the grey to black cover and bimini boot. View attachment 219613View attachment 219616View attachment 219618View attachment 219620View attachment 219621View attachment 219622
View attachment 219623View attachment 219624View attachment 219625View attachment 219626View attachment 219627
