MrChew1667
I believe they are the brackets used for the delivery from the factory to secure the tower down. Most are thrown away before owner gets the boatThese came with a used 2017 AR 240 I recently purchased. Any ideas what these are for?
Those are like gold
If you use a winter cover from factory you will need them. Also they are nice when storing the boat for long periods of time since they will take the weight off and secure the tower. Also if towing with the tower down the would be used so the tower doesn't bounce
Main reason I am looking for them is I am going to store my boat high and dry in the marina, but it will be with the tower folded down. So I was thinking it may be best to have those shipping brackets in place, just in case they bounce the boat while fork lifting it in and out. I don't want the tower cables to snap. Maybe overkill. Any store their boat high and dry with the tower down? ever have any issues?This.
Undo the screws for the tower, lower the tower, and the tower screws now go in the round part. The bolt and washer are used to fasten the flat part to the deck of the boat. Holds the tower in the perfect position for the white shipping cover, if you have it. If you don't have that, @HangOutdoors has the only reasons to keep them. Your decision if you feel the need to utilize them for such reasons.
I don't, but Yamaha uses them when they ship them (mainly to get more boats on the truck). I think the manual specifically says to tow with the tower up.Should you use these for long distance travels?
Julian - can you post a picture of the ones you made out of wood, whenever you get a free moment? Thanks!I don't, but Yamaha uses them when they ship them (mainly to get more boats on the truck). I think the manual specifically says to tow with the tower up.
When I tow long distances I keep the tower up, and I tape all the leading edges with painters tape so bug removal is easier on arrival.
For those who don't have these, I fashioned some out of wood for a local member who didn't have them, used mine as the template....worked well.
I would be happy to....if I'd taken a photo. And I dont recall the member name i made them for!Julian - can you post a picture of the ones you made out of wood, whenever you get a free moment? Thanks!
