Cambo
- Long Island
- 242X E-Series
Unfortunately this new law now bans some of my favorite lakes for wakeboarding in Vermont. We don't even use ballast or attempt to wake surf while on the smaller lakes knowing they are just to small but, the boats that load up with 4k plus pounds of water and weigh almost 2000lbs more than a Yamaha have been creating issues in Vermont with eroding shores and damaging docks. Now the new laws are in effect limiting the location within the lake and what lakes you can use for "Wakesports" based on acreage and water depth. They also added a new "home lake rule" that requires a sticker that needs to be displayed.
“Wakeboat” means a motorboat that has one or more ballast tanks, ballast bags or other devices or design features used to increase the size of the motorboat’s wake.
“Wakesports” means:
A. to operate a wakeboat with ballast tanks, bags, or other devices or design features engaged to increase the size of the boat’s wake; or
B. to use a surfboard, wakeboard, hydrofoil, or similar device to ride on or in the wake:
i. directly behind a wakeboat without a rope; or
ii. directly behind a wakeboat with or without a rope, when the wakeboat has ballast tanks, bags, or other devices or design features engaged as described in Section A. above.
“Wakesports zone” means an area of a lake, pond, or reservoir that has a minimum of 50 contiguous acres that are at least 500 feet from shore on all sides, at least 20 feet deep, and at least 200 feet wide.
A wakeboat’s Home Lake is the only lake, pond, or reservoir at which that wakeboat will be used for the calendar year.
However, a wakeboat can be used in a body of water other than the identified Home Lake only after that wakeboat has been properly decontaminated to prevent the spread of aquatic invasive species. Prior to entering a Vermont waterbody other than the wakeboat’s Home Lake, and prior to reentering the waters of the Home Lake after use of the wakeboat at any other waterbody, the wakeboat must be decontaminated at a Vermont Agency of Natural Resources approved decontamination service provider. A wakeboat user may be requested to provide proof of decontamination at public access areas.
“Wakesports” means:
