MidnightRider
- Zumbro Falls, MN
- Malibu
- Wake
The new PP is posted to JBP website - not seeing anything earth shattering here. Maybe hints at a less complicated install? But did we really need a less complicated install - I thought R-S was dead simple install the way it was. Then there is the glaring absence of the "knob" style interface.
I think it was inevitable that PP did this, even if JBP didn't push them, but all I see here is maybe some performance tweaks that will push R-S to be even better and that's a good thing.
Maybe there are details I'm missing. This is definitely a contender as a competitive option/alternative to R-S, but given what I see here, I'd still be an R-S customer if I was choosing today - did I mention the knob interface - sorry I'm a believer in it. ¯\_(ツ)_/¯
jetboatpilot.com
Features:
Perfect Pass Stargazer Wake Edition S
PerfectPass has totally reimagined, redesigned and simplified the GPS Star Gazer Wake Edition for most Yamaha Sport Boats**. The same engineering team that designed speed control systems used in Pro Events around the World has once again set a new standard for jet boats with the industry’s...
Features:
- Nearly a “Plug & Play” installation process for boats with wall mounted Accelerator Position Sensors (APS). No servos to install, no constant power required, no messy RPM Cables to connect and no wires to Splice.
- High quality Automotive Type Connectors that meet NEMA Standards.
- Genuine Garmin weather proof GPS Receiver.
- Engineered to be fail safe. Any loss of power to PerfectPass or any cable failure to PerfectPass will result in full normal operation of boat.
- Ideal for Surf speeds from 8 mph and up.
- Simply set the speed, throttle up and PerfectPass will take over automatically once the set point is reached.
- All new “Two Stage” engagement process developed exclusively for Yamaha Systems to provide our most seamless engagement ever.
- Incredibly smooth pull that holds speed to within a few 10ths of a mph and no rpm oscillation.
- Includes your choice of our 3.5 inch round Display Gauge or External Display with Mount for boats with “Connext”. (No extra charge)
- The LCD screen with adjustable backlight shows you just what you need to see in a clear, uncluttered format. No complicated Menus to scroll through.
- Available in Single and Twin Engine formats.
