MrMoose
- Calgary, AB, Canada
Hi all. If you have a newer 24 foot hull, can you check your anchor locker drain fitting? Is there an inner flange and an outer flange, or is it just an outer flange? I expected the fitting to be two pieces because the part number description on the Yamaha parts website refers to it as an assembly. I expected that there would be an inner flange that mates with an outer flange so that the water can drain from the locker past both the inner and outer hulls.
My 2015 does not have an inner flange. I assume that it may not have been installed at the factory because there is a plastic bracket (to hold the anchor arm in place) installed over the drain location.
If it's supposed to be a two piece drain, then I'll order the part and install it properly after I modify the plastic bracket to make room.
I just don't want to order the part (F2D-U2290-00-00) just to find out that it's just one piece (outer hull flange).
Thanks!
Thanks!
