Oil Catch Cans: A must-have for all FI/SVHO applic
Griswold
Good Morning All My Cool Cats and Kittens,
Not to dredge this up again however I’ve received numerous IMs from folks in response to my previous post below and I thought it easier to put an explanation here as to why this part should come standard on every forced induction outfit out there today. Simply put, blow-by is a real thing on these engines and for those of you familiar with this performance-robbing phenomenon, it’s also bad news for engine internals and components. For more on how blow-by affects your engine I suggest googling “How Oil Catch Cans Work” as I won’t burden this group w the granular details here. Most of the IMs I’ve received have asked where this device should be mounted. That said I’ll slap a couple photos here that should explain it whereas I mounted mine in place of the brackets for my stock air intake box. For any other questions on this please feel free to reach out. Hopefully this very simple install helps increase your FI engine’s output and prolong its life keeping all of you social distancing the proper way...on the water. Cheers! :)
I noticed that has an option to run without filter on top. Any Pros/Cons?
It comes w the filter on top so I put it on. Maybe personal preference but I don’t think it hurts getting more oxygen to the intake, especially when it starts to heat up outside.
I have the breather tube but I am considering to change to catch can.
Certainly less maintenance and cleaner for your boat’s internals as well as the atmosphere.
What brand did you buy for a catch can and where did you buy it any info helps thanks
Neither one of those guys has been around in a while. Did you check the link @Griswold posted?
My two cents, I wouldn’t run the filter on top of the catch can, I’d let the induction system pull all the gases from the engines crankcase into the engine. Otherwise the engine bay could smell like oil.
