OnTheWater
- Denver, NC
- Boatless
- NA
- Other
- NA
@Gym @itsdgm  Well, still have a leak - not as fast as before, but still there.  The guys at The Resort Boat Shop in Coeur d'Alene did all they could to troubleshoot, but since they don't work on Yamaha's or jets (Cobalt, Malibu, Carver, and custom wooden boat dealer) they didn't want to go any further b/c of cost.  They had it for 2 weeks, did some troubleshooting, caulked/siliconed, put it in and out of the tank 3 times - no charge.  Gr8 guys!  They said I could use their tank again after my Yamaha dealer does the warranty work, so I can make sure it is good to go.
Picture of 'The Full Quiver' in the tank. 'Full' is taking on a new meaning these days...
Starboard side - looking through the access hatch between the two clean out plugs. There was a hole in the silicone on the right side, which Resort guys sealed. Water is coming in much slower now(can't see where), but still coming in. Water is pooling in the cavity on the right side of the black hose with blue siding. Once that is full, it fills the center cavity, then over into the engine compartment.
All LED's, scuppers, hardware are bone dry, so we're thinking there is a cavity underneath what you're looking at below that isn't sealed and when the water comes up in the jet intake, that it is leaking up. Dropped it off at the Yamaha dealer and walked them through what we have done and they'll be working on it as warranty work. Hopefully they can figure it out and get it done quickly.
Different angle - you can see the water on the other side of the hose. That's about 5 minutes worth.
Different issue - small leak on port side(next to the clamp screw by the hose)
This is the worst part of it all...
