JohnB
- NE Ohio
Seem like very trip out, I'm finding bolts and screws loose and falling out of the boat. Do others have issues like this with quality control of assembling the boats?
After the below, I spent 2 hours going around the boat checking for loose bolts, screws and fittings and was surprised at the number loose. Also found some stripped and 4-5 Phillips heads where the head was mangled during assembly. Is this typical for these boats? Are there other things that I should be on the lookout for. It's a lot of coin for a boat that needs gone over like this.
So far:
rear compartment hinges were loose and latches not lining up
latching spring mechanism was found inside the compartment for above
mounting bolt fell out of passenger seat
Ski locker strut screws fell out of the locker door. When I went to put those back in, it was obvious why they fell out as the holes were stripped
Have a black phillips screw that I still haven't found were it goes (was near the passenger seat)
Strut on the anchor locker has 3 screws in the door side (with 1 stripped), 2 in the boat side that were loose.
Rear ski tow hook started loosening up and moving around on the fiberglass. nuts were finger tight at best when I went to tighten them
So far:
