- Royal, AR
- SX
SeaStar / Teleflex manufactures the steering and shift cables for Yamaha boats.
Their OEM parts are available at lower prices than the Yamaha parts.
For the 2007 to 2009 230 range the part numbers are SSC21917 for steering and CCX63318 for the shifter.
If you know part numbers for other models please contribute them to this thread.
Looking through their parts catalog they have components listed for the mechanical steering system used before 2015 and the rack steering system used on later boats. @Julian do you think there would be any value in upgrading older boats to the rack system?
I have emailed and left a message for SeaStar hoping to learn if any newer (better) parts exist for my boat. Currently I believe that the SSC219XX series is the latest unless I upgraded to the rack system.
Here are the relevant sections from their catalog. Click them to enlarge.
Here is a little info I have learned in this process.
1. SeaStar recommends "greasing the telescoping end at the engine often". I believe this means the telescoping end by the jet.
2. The SSc21917 /F1C-U1470-10-00 steering cable has never been upgraded. So you will receive the same product wherever you buy it.
3. I believe that the F2A-U149C-00-00 reverse cable has been upgraded to F2A-U149C-01-00 and that the later cable is SeaStar part number CCX63318. SeaStar tells me that this part number is from their latest and greatest XTreme product line.
4. The 2015+ 240 use "rack steering" from SeaStar with XTreme steering cables. The parts are only available through Yamaha and I believe it would cost around $700 to retrofit. Doing so would increase the number of turns of the wheel required while decreasing the force required.
Here are the part numbers that I am aware of for these cables. I have attached a spreadsheet so you can copy and paste them. I have asked SeaStar about their part number for the throttle cable.
What kind of ongoing maintenance do cables need? Can they be repaired?
We suggest the following periodic maintenance be performed at least twice a season:
- Check overall operation for proper gear engagement, full and idle throttle, and
overall feel. - Visually inspect control head cable, as well as engine and transmission cable attachment points for
proper tightness of fasteners, correct operation of all moving parts, worn or broken items, cable
chafing or misalignment, etc. - Do not lubricate core wire (moving wire inside the casing). If the cable operates stiffly, replace it.
- Keep cable ends dirt and corrosion free.
- Lubricate pivot points and sliding parts of the cable with a good quality, water-resistant grease.
- Excessive free play felt at the control even after all cable connections have been verifed as in good
working order. - Visual inspection shows signs of cha ng, breakage, bent, loose or worn parts.
