bronze_10
- Raleigh / Wake Forest Area..
- SX
I did mine in the fall and I ordered two 17 foot cables
Other than some very early models I believe that all twin engined Yamahas use cables of the same length for both sides. The routing through the center of the boat makes the cable length the same.Did you ever find the answer to this ? Or what the reverse cable part is?
Here are some links to a decent prices on the Yamaha part # for your reverse gate cable:Hate to bring this back but my 2015 needs new cables and looks different than what my older sx230 had. Does anyone know the part number from Seastar for a 2015 242 LS? It looks similar to their rack steering package. The cable part number is SSC14417.
https://www.starmarinedepot.com/seastar-ss141-the-rack-steering-package-14'.html
Seastar doses make the rack steering. If you call they can help you find the part numbers.Hate to bring this back but my 2015 needs new cables and looks different than what my older sx230 had. Does anyone know the part number from Seastar for a 2015 242 LS? It looks similar to their rack steering package. The cable part number is SSC14417.
Say Hey All, @Bruce the above part numbers are solid for the 212x (21 footers). shout-out to @bronze_10 for giving me a solid days labor in the heat to replace these 4 cables, and the knowledge to help someone else. My boat is a 2009 and has about 200 hours on it. Its garage a great deal and soaks on the weekends. overall the old cables looked fine, I haven't hacksaw'd thru them yet but I don't expect anything to come of it. The new ones do feel better and I'm expecting/hoping that the throttle creep will be gone as a result of tighter bucket cables....Hey There @Bruce @bronze_10 I just ordered steering/control cables for my 2009 212x.
I ordered the steering thru Ebay for a Seastar SSC21916 (16ft) cable for $$127.98 ($255.96) . Best I can tell 16ft is the factory length and echo'd by @smthng here.
I ordered the control/bucket cable thru boatstoreusa.com Teleflex part number CCX63317 (17ft). $36.38 ($72.76+$10 ship)
The factory length on this cable is not clear to me, I chose 17 based on the 230's being 18, and conversation with @bronze_10 .
Hope to install them next weekend. Will edit if required
THANK YOU
@Bruce ,SeaStar / Teleflex manufactures the steering and shift cables for Yamaha boats.
Their OEM parts are available at lower prices than the Yamaha parts.
For the 2007 to 2009 230 range the part numbers are SSC21917 for steering and CCX63318 for the shifter.
If you know part numbers for other models please contribute them to this thread.
Looking through their parts catalog they have components listed for the mechanical steering system used before 2015 and the rack steering system used on later boats. @Julian do you think there would be any value in upgrading older boats to the rack system?
I have emailed and left a message for SeaStar hoping to learn if any newer (better) parts exist for my boat. Currently I believe that the SSC219XX series is the latest unless I upgraded to the rack system.
Here are the relevant sections from their catalog. Click them to enlarge.
2. The SSc21917 /F1C-U1470-10-00 steering cable has never been upgraded. So you will receive the same product wherever you buy it.
Doug,@Bruce ,
I notice the AR190's in your chart/XLS only have a part # for the reverse cable. However, you posted a picture above of the Jetboat steering cable SSC219XX (XX is the length). Do you know if this cable will replace the OE cable (mine is a F3A-U1470-01-00) (2015 AR192) ?
@Bruce,Doug,
SBT lists your cable length as 170.125 inches.
That is 14 feet 2.125 inches.
I would hate for your cable to be 2.125" too short so SSC21915 would likely be the best choice. There is no issue with it being too long. I see prices starting around $114 for that part.
PartsPak has the Yamaha Cable for $131.
If you order the Seastar cable please confirm it works. I am almost certain that it will.
I didn't listen to @Bruce in this thread and replaced my steering cables without replacing the control cables last year. Guess what I am doing this year? Yup, replacing the control cables. Only one is bad but I'm replacing both.Just placed an order for two 17' cables. The cheapest place I found was Marine Parts Source. $120.17 with free shipping.
Jet Boat Steering Cable - 17 Ft.
I am pretty sure that the 2015+ cables are listed in the SeaStar parts catalog. Not as Yamaha parts but as newer offerings from Seastar. A call to tech support might help identify them.Great find has anyone sourced the newer cables im not sure when they changed 2015?
Which number on the diagram appears to be the grommet?...so, I have to replace the steering cable on my 2015 SX192; yamaha PN F3A-U1470-01-00 from here:
2015 Yamaha SX192 (RM1800DP) Steering | CyclePartsNation
Shop online for OEM Steering parts that fit your 2015 Yamaha SX192 (RM1800DP), search all our OEM Parts or call at 269-385-1540www.cyclepartsnation.com
My question is: There seems to be a grommet through where the cable is inserted but I see Nuts on the cable that make me think it's tightened/sealed in the grommet..?!?
Does the cable just slide through the grommet?
Thanks guys!
Zinc-Plated Steel CouplingNut, Low-Strength, 5/16"-24 Thread Size | 2 Each |
#20Which number on the diagram appears to be the grommet?
