- Royal, AR
- SX
You are partially correct.
The worst case scenario is when a plug blows out at high speed and lodges in the clean out tube vs hitting the hatch cover (and often breaking it and killing the engines). When this happens the force of the water in the intake gets partially directed into the cleanout tube, blows off the rubber hose that connects the pump to the clean out tray and starts flooding the boat VERY quickly. The driver will feel some reduced thrust when this happens, and if he stops the engine, the pressure in the intake will increase as the pump isn't pulling the water through any more. This increases the water flow through the disconnected clean out tube into the bilge. Most people have only seen a slight disconnect of the clean out tube, but imagine if it blew off completely! You'd have an approx 5" hole in the bottom of your boat, connected to a scoop that is driving water at it HARD. In that scenario, I could imagine a boat going 50MPH with a 5" hole connected to the intake could fill the bilge and engine compartment COMPLETELY before the boat came to a halt (so not even my bilge alarm solution would help you). Fortunately not one has ever said that the hose disconnected completely (but perhaps that is what happened to the OP here)? I've reached out to him and will update us if he responds.
My first experience in a Yamaha Jet Boat was the twelve year old extremely poorly maintained LS2000 that I mentioned previously in this thread. The hose was not connected to the tray. The tray was actually bouncing around loose without any screws. The plug had wedged sideways in the tube while the dealer was driving. My guess is that when the boat was on plane the water that was pumping into the bilge was distributed evenly but when the dealer stopped to let me drive it shifted to the stern. When I throttled up the boat was so full of water that it would not plane. I discovered the plug blowout. I was not able to push it down so I pulled it out and tried to reinsert it. It was so swollen that I could not get it to lock in place. The stern was so heavy that when I removed the plug a fountain of water came out and directly into the bilge. We were about 5 miles from the ramp. Another boat towed us to the ramp. I stayed at the stern with one foot in the bilge and the other in the lake holding the plug in place. I do not know if it would have sunk but the entire swim deck was under water by the time we got it on the trailer. The boat was so heavy that the trailer tires looked flat when we pulled it out. I towed it back to the dealership with the drain plug out. When we unhooked the boat the stern was so heavy that the tongue shot up and had to be held down. The engine compartment was full of water.
This happened because of a lack of maintenance. Had the plugs been rebuilt or replaced it is likely that it would have been properly inserted and not have popped out. Had the clean out plug tray been in place it is likely that the water would have flowed over the back of the boat instead of into the bilge. In my experience it was not Yamaha's fault but that of the previous owner and the company that maintained that boat.
