Tex72
- Lake Conroe
Some of you may have seen my post on another thread, about my install.
I recently replaced the perfectly good factory foam, in the engine bay, & installed some sound mat in it’s place.
(Note: the foam removal & mat install took approximately 4 hours, and it was a pain.)
I took the boat out yesterday, and the results were not good:
I would say it was not better than the factory foam, and maybe worse (@adrianp89 was correct in his take on this).
At higher RPM’s, the “Hornets Nest” sound does seem somewhat muffled, but the engine is at least as loud as before…and there are “new”/different engine noises, At idle & lower RPM, I would say it’s louder too. My wife & son felt like it was about the same (in general), but I felt like it was a little worse.
I plan to install some soundskins CCF over the sound mat, & I expect it to be better…will update after new install.
Overall, this install was not worth the time, effort, & money. Hopefully the sound mat & CCF combo will be better than the factory foam, but I’m not expecting miracles.
